Dimensioning
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
Scary99
505 Aufrufe, 4 Antworten
Dimensioning
I am attempting to revise the dimension value in a floor plan.  When I click on the dimension I get a box that will allow me to substitute text for the dimension but cannot enter a numerical value.  This has only occurred on the exterior wall dimensions.  I checked and I do not have these walls dimensioned on other plan views therefore they are not locked.  I can edit dimensions when placing doors, windows and interior walls.  Any suggestions?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Scary99
You have to select the element you wish to move then you can type in a value for the dimension.
Nachricht 3 von 5
Scary99
als Antwort auf: ToanDN
I get a "Dimension Text" box when I pick on the dimension that I want to edit.  It will not allow me to replace the dimension with a different numerical value it will only allow me to enter a text description of the dimension.  I need to enter a numerical value such as  34'-0".
Nachricht 4 von 5
Do not pick the dimension. Pick the element (wall, door, window or whatever) then the dimension will turn blue and you can enter the value.
Nachricht 5 von 5
jlg_design
Hi Scary99,
Unlike AutoCad, where you can override a dimension, Revit does not allow this. To change the dimension to the number you want, you have to actually move the element as ToanDN suggested.
Jeff
