Dimensioning with Linked Models
clara_csdrafting
clara_csdrafting
How do we not dimension modeled geometry of linked models in our projects?
For instance, if I create my own stuff in line with elements from an architectural central model so they're in perfect alignment, I then dimension by tabbing through the pop-up indicating what my cursor is currently over -- or, by turning off the architectural model altogether.  I'm looking for an icon like "Select Links" or "Select Pinned" Elements" to toggle on/off the ability to dimension to linked models.
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
dzanta
by default, dimension command will see linked files.  You can turn off the linked file before dimensioning.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
L.Maas
In those case why not select link and use temporary hide.
Louis
Please mention Revit version, especially when uploading Revit files.
dzanta
you can do that too.
Lance.Coffey
Autodesk Support
Autodesk Support
@clara_csdrafting Have you thought about submitting this idea to the new Revit Idea Station?
http://www.autodesk.com/revitideas
Lance Coffey
Technical Support Specialist
clara_csdrafting
Thanks, everyone.  It seems others have this need and are handling this in similar fashion themselves.  Would be helpful for Revit to have a toggle-like tool for this.  That way we can leave linked in models for reference within our projects as we work (for reference).
Thanks for the idea link.  2nd one today.  Smiley Surprised
