Dimensioning Wall Sweeps
6 ANTWORTEN 6
Nachricht 1 von 7
534 Aufrufe, 6 Antworten
After installing Revit 2020 I tried to dimension a wall sweep.  When I try to tab to the appropriate location nothing highlights and therefore I must blindly click around the area and hope that it picks the right element to dimension to. In addition, when I click to finalize the dimension location there are no witness lines to be found.  They are actually located approximately 150' above where they should be.  Please watch the attachment of the problem.
Thank you for any help given
Tags (1)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Weird. Is your current workplane askew to the view?
Nachricht 3 von 7
als Antwort auf: barthbradley
Nope, in fact I just had a co-worker dimension one of his wall sweeps and his witness lines are showing up about 25' below the dimension.
Nachricht 4 von 7
Viveka_CD
@Anonymous
Have you shared the file with us?
Nachricht 5 von 7
als Antwort auf: Viveka_CD
Yes, I gave you permissions about a week ago.
Nachricht 6 von 7
Viveka_CD
Nachricht 7 von 7
Viveka_CD
@Anonymous
The issue is in progress and is being investigated for a resolution!
