Dimensioning to Wrapped Core Layers at a Mirrored Door
9 ANTWORTEN 9
Nachricht 1 von 10
dominic.bond
649 Aufrufe, 9 Antworten
I need to set out the core of a wall that has finish layers wrapping at inserts (a structural metal stud wall with plasterboard fire protection).  This has been going well until I come to a door that has been mirrored when Revit won't snap to the core layers, only the finish layers (see image below).
Anyone know if I can sort this without having to create a different family for each door type or by adding reference planes into the door families (there are quite a few different door families)?
Thanks.
9 ANTWORTEN 9
Nachricht 2 von 10
Tom_Kunsman
als Antwort auf: dominic.bond
are you actually mirroring the door or does the door have a horizontal flip control as part of the family?
Nachricht 3 von 10
dominic.bond
als Antwort auf: Tom_Kunsman
I'm using the flip controls in the door family.
Nachricht 4 von 10
dominic.bond
I've also now tried mirroring 'manually' using the Mirror tool and this doesn't work either.
As a test I tried copy-pasting the wall, doors and dimension line into a new project and this seems to work; it allows me to edit the dimension lines and they now snap to the core layer!? However, if I copy-paste into a new location within the same project, it doesn't work!
Nachricht 5 von 10
hmunsell
when you say "Mirrored" do you mean the door was mirrored using the mirror tool (modify ribbon > Modify panel > mirror) or were they mirrored using the Flip control in the family ?
if the door does not have flip controls they can be added by editing the family (Create ribbon > Control panel). the flip is controlled by the Front/Back and Left/Right reference plains.
Howard Munsell
Nachricht 6 von 10
dominic.bond
als Antwort auf: hmunsell
I've tried both options without luck, see posts above.
Nachricht 7 von 10
If you don't come right, post the family here so that we can test it.
Nachricht 8 von 10
dominic.bond
Thanks everyone, I've sorted it now.  It seems to have been a problem with the wall rather than the door. Through trial and error I found another wall that seemed to work ok so I just duplicated that and changed all its properties to match the first wall.  This seems to have fixed the problem.
Nachricht 9 von 10
RDAOU
@dominic.bond
Flip the wall it was hosted on to match Int/Ext with that in the door family...
Alternatively, you can set the wall to "Wrap Both" Interior and Exterior and set the Closure plane to the middle of the host...that will sort out the snapping issue to core at inserts.
Nachricht 10 von 10
Wall Closures Ref. Planes' inset distances can be driven via parameters.  Why not just change those to resolve dilemma?
What about driving your Wall Closure Ref. Planes' insets distances with Type Parameter and making "mirror" Types? For instance: Door Type "2868" and Door Type "2668M" ("M" for Mirrored).  The only difference between the two, is the Wall Closure Ref. Planes insets are reversed.  In other words, 2868's Wall Closure Ref. Plane is inset 3" from the hinge side, and 2868M's Wall Closure Ref. Plane is inset 3" from the opposite side.
