Dimensioning to center of curtain wall opening
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
emasame
2335 Aufrufe, 4 Antworten
Does anyone know how to accomplish this? In place of window families we made a bunch of curtain walls with irregular mullion spacing. I do not want to dimension to the mullions but the center of the cut opening.
If you know how to dimension to the center of a curtain wall panel even that could help a lot. We have some "windows" with a panel that is centered in the opening already.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: emasame
You need to place a reference plane and dimension to it.
Nachricht 3 von 5
I can think of one way...use a loadable Curtain Wall Panel.  They have a Center Ref. Plane.  You could add any IS REFERENCE Reference Plane to snap to in the Project.
Nachricht 4 von 5
emasame
als Antwort auf: ToanDN
Does the reference plane associate with the curtain wall? Our workaround
has been placing a tiny detail line to dimension to. Does that function
identically?
Nachricht 5 von 5
No. Another way is not cutting the wall with the curtain wall, place a separate opening family with a center line ref plane to cut the wall, match with size with the curtain wall and lock them together. Then, you can place a dimension to the center line of the opening.
