Hey guys. I need some help on figuring out how to do something in Revit. This structured wall was designed after a horn, as it moves higher the center point arcs and the ellipses get smaller.
I am trying to detail out a stair cone wall at 4 foot increments in a plan view so the the contractor in the field can build a form for the concrete.
From the basement floor level to the top of the structure is 24’. I need to dimension the center points at each 4’ height increment along with the overall ellipse size at that height. I also need to keep the center point noted on the bottom of it along with noting it at the cut plane for that view.
The problem is I can only dimension to the center point and ellipse points at the plate levels. It will not allow me to choose the wall portion at the cut plane that I specified in the properties for the views I created. Is there another way, besides creating individual floor levels for each cut plane I would like. This may go to 1' increments once the contractor reviews the details. I am trying to avoid having to go through all my currents elevations and sections and turn off all the newly create floor levels that i will need to create.
Any ideas on how to do this? I also need to keep the center point noted on the bottom of it along with noting it at the cut plan for that view.
Thanks for your help in advance.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
