Dimensioning quirk: Show opening height
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is one for the Autodesk employees on this forum (didn't really know how else to addres this issue).
I've encountered a bit of a quirk in Revit's dimensioning.
In the parameters of a dimension type you can select "Show Opening Height".
Problem is, this doesn't just read the height parameter of doors and windows, but of any family that has a built-in height parameter.
E.g. structural columns (in this case 41.5 x 43) or beams 43x70).
So If your dimensioning a side of a room where there's a wall with several doors and columns, you'll get some confusing dimensions.
Even casework (e.g. Base cabinet 45x60x86):
Either Autodesk needs to rename the dimension parameter to "Show Height", or reprogram it to only read heights in doors and windows.
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
