Dimensioning issue
1 ANTWORT 1
Nachricht 1 von 2
231 Aufrufe, 1 Antwort
Dimensioning issue
I am new to Revit--trying Revit LT 2017. After sketching a floor plan and when I go back to refine the dimensions, when I change the value of a segment,  the value of the adjacent segment changes too so that the total stays the same. How do I fix that?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Select the item that you want to modify...then select the dimension that will change its location...hint, it will change to blue text when it can be modified.
