Hi all, I'm relatively new at Revit, so forgive me if it's an easy fix.
I've been struggling with trying to figure this out, but why exactly does it seem like I have no dimension in my section cuts? I've been trying get a cut of the lumber I made with dimensions added, but something seems to be acting funky.
Looking at my section cuts 2 and 3, they're both just dots. They seem like rectangles in the shape of a cut through the lumber, but I can't annotate or click on it.
Thank you!
I see it now! Thank you so much.
But why is it so small? Is there a way to blow it up without changing the dimensions? I'm trying to have it be a clear view on a sheet.
Change the view to a larger scale.
You can also turn on Thin Lines display.
