Dimension- turn off single arrow head and extension line
2 ANTWORTEN 2
Nachricht 1 von 3
mmcintosh-ral
2344 Aufrufe, 2 Antworten
Is there a way to turn off the arrow head and extension line on one end of a dimension?
Or, is it possible to set up a specialized dimension type/style that would show just the dimensions line + text, with an extension line and arrow only at one end?
thanks for any info/ideas,
Michele
2 ANTWORTEN 2
Nachricht 2 von 3
Sahay_R
als Antwort auf: mmcintosh-ral
You can create custom Dimension styles - if you Edit Type in Properties, Duplicate and Rename. Once that is done you can set it up the way that you want.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 3
You cannot do that with Revit dimensions.  But you can create a line based detail family with extension line + arrow on one end, and a label reporting the length.
