dimension text location setting
3 ANTWORTEN 3
Nachricht 1 von 4
andrewsdraftingservice
1328 Aufrufe, 3 Antworten
hello i would like some help editing the settings for dimension lines.
when i dimension, the text appears above the dimension line (example A). what i would like is to have the text appear in the dimension line (example B) what setting do i have to adjust to have example B as the default dimension type? thank
3 ANTWORTEN 3
Nachricht 2 von 4
Centered? Can't be done natively.
Nachricht 3 von 4
sharmayne_lim
als Antwort auf: barthbradley
hello there! thanks for the reference but i cant find springs.doc.activeview, dimension.getcurve and dimension.settextlocation :enttäuschtes_Gesicht:
only managed to get these... would appreciate some help! if possible, could you send over the file or enlighten me where to download packages for the missing nodes? thank you so much!
Nachricht 4 von 4
alaraJ3LSY
als Antwort auf: sharmayne_lim
See Dynamo Ribbon.
Click Packages
Search
Rythm
spring nodes
