Dimension Style
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Mohamed_Arshad
814 Aufrufe, 3 Antworten
Dimension Style
Hii Geniuses,
How to create the below dimension style in revit.
Thanks & Regards,
Mohamed Arshad K
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Mohamed_Arshad
You should be able to get something similar with 2 dimension styles.  Note that dimensions can be Continuous or Ordinate (you can also select baseline which will separate them.Dims.JPG
Nachricht 3 von 4
use two overlapping  Type Dimensions styles:
  • one type - Dimension String Type: Continuos
  • the other type-Dimension String Type: Ordinate - text background transparent
    • with text background transparent
    • Ordinate Dimension Settings : Text Orientation: Parallel to Witness Line
    • Read convention: Left then Up
Constantin Stroescu
Nachricht 4 von 4
bgerges87PPP
That's soo helpful. Thanks.
