i have a string of dimensions that do not add up to the total length dimension string. there is a dimension in the multi-string that is 1/256" off. i have my rounding set to the 1/256" so this way i get a true dimension. i would like to know if there is a fix for this? not necessarily a work-around. i am attaching a revit file that shows this issue.
Gelöst! Gehe zur Lösung
Gelöst von David_Knight. Gehe zur Lösung
it's the 29'4" dimension.
if you click on the wall between the "29'-4" and "17'-11 255/256" dimension - then type "29'4" on top of the "29'-4 dimension" and they will all fix themselves.
whomever placed these walls got them off a hair when placing them. this looks like user error to me.
I attempted your suggestion with no luck. I have made a screencast for you to view and see if I was following your directions correctly.
my bad.
i think i got lost in someting and didnt get my whole thought out.
here, i made a screencast for you.
I had to adjust all the dimensions starting on the left.
