Dimension string not showing equal symbol
Message 1 of 22
Hello Everyone!
I am a beginner and now trying to build a sliding door using the Metric Door.rft as a template. I put 2 dimension strings to divide the door height and wanted to set the two dimensions to equal but for some reason the EQ symbol is not showing. If anyone could explain what I am doing wrong, that would be great.
Dimension string: EQ symbol not showing
Replies (21)
Message 2 of 22
ennujozlagam
hi, try to pick the dimension and EQ signs will appear above the dimensions. thanks
Message 3 of 22
Hi Ennujozlagam,
If I select the dimension, the only symbol it shows is the open padlock... Any idea why this is happening?
Message 4 of 22
ennujozlagam
hi, any possibility you post your file so we can check. thanks
Message 5 of 22
RDAOU
Jon the image you attached shows 1 lock above the the dimension. That means you drew two dimensions each separately. To have the EQ they need to be continuos. Start from bottom or top the the middle then the other end ...
Message 6 of 22
ennujozlagam
@RDAOU, ya,, you're right, i didn't realized that. thanks
Message 7 of 22
RDAOU
@ennujozlagam At first I missed out on it too 🙂 but then I was (Oh! 1 lock)
@Anonymous here is a screencast in case my wording was not so informative. Hope this helps
Message 8 of 22
Hi ennujozlagam,
Thanks, I am sending the file for your reference.
I tried again, and this time the EQ symbol shows however I now get the message "Toggling the dimension's equality constraint would overconstrain the sketch." I have attached the file for your reference.
Message 9 of 22
Hi ennujozlagam, I don't seem to be able to attach a file... So attaching a printscreen instead.EQ symbol2.PNG
Message 10 of 22
@RDAOU, thanks for the great screencast! However, as I mentioned to ennujozlagam above, now Revit says "Toggling the dimension's equality constraint would overconstrain the sketch." If you could help me on this, that would be great. Thanks Guys!
Message 11 of 22
ennujozlagam
hi, zip the file and post it here. it will work. thanks
Message 12 of 22
RDAOU
@Anonymous you are welcome; unfortunately this is the only solution to have EQ appear.It is not functioning because you either locked more than 2 vertical dimensions linked to the panel or interfering with it or because you EQ would rely on other elements of the door which are locked/constrained hence ristricting the panel from redimensioning to preserve equality with respect to the reference Plane in the middle.
In the door you are drawing: The EQ will basically try to relocate the Reference plane in the middle either Up or Down to keep it in the middle between the Top and the bottom constraints. I would check if in this view or another view there is something else constraining this movement. Otherwise zip the file and attach it here and @ennujozlagam will do fix for you.
I personally would recommend that  you look more into Families tutorials to understand how constraints work.
Good Luck
Message 13 of 22
Hi ennujozlagam,
Thank you for the reply!
Sorry, I was away for a couple of weeks.
That is great, it indeed works if I zip the file. Please see attached.
Message 14 of 22
@RDAOU, thanks! And sorry for the late reply...
I completely agree with you that I need to practice the families tutorials more so I better understand the constraints. In fact, this is what I am doing and tried to build this sliding door I have in my flat but it seems the tutorial I based on does not cover the issues I am having... This is the tutorial: https://www.youtube.com/watch?v=aVxLWXAD-cY
Could you suggest me a good tutorial for families?
Thanks!
Message 15 of 22
ennujozlagam
hi, i already open your file and do some changes. 1)remove your referance plane and create new one. 2) remove your frame/mullion and create new sweep profile change location and lock to the reference plane. I attached your file back. hope it helps. thanks
here are some tutorial a simple parameter door.
Message 16 of 22
ennujozlagam
Message 17 of 22
@ennujoslagam, thanks a lot for looking into and correcting it, much appreciated!
Also, thanks for the great tutorial. Will follow it step by step and hopefully will get the hang of it soon 🙂
Message 18 of 22
ennujozlagam
@Anonymous Hello, no worries, glad to help. thanksSmiley HappySmiley HappySmiley WinkSmiley Wink
Message 19 of 22
rayez54751
you have the volume on the video turned off
Message 20 of 22
prajna1810
Community Visitor
Community Visitor
Its still showing the same for me even after trying to label the dimension continuously. Could someone help me with this
