Dimension parameter sweep path in family
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1089 Aufrufe, 5 Antworten
Hi guy,
I am trying to dimension a Solid Sweep Path to a ref.plane into a family.
I have created a door handle using Solid Sweep tool and Pick path. I would like to keep the handle tied up to the central ref.plane?
Is there any way to keep the sweep volume linked to a ref.plane?
Please find attached a couple of snapshots showing the issue.
Thank you very much.
5 ANTWORTEN 5
Nachricht 2 von 6
Kushnir.A
als Antwort auf: Anonymous
Hi! Try to align handle with ref.plane and create constraint.
Best regards, Alexey Kushnir. | Facebook
Nachricht 3 von 6
Create the handle as a nested family. Much easier to constrain.
Nachricht 4 von 6
als Antwort auf: Kushnir.A
Hi guys,
Thanks for your swift replay. The handle is for a parametric door family. The problem is that the handle doesn't constraints to the carpentry when changing the door size. I have also tried creating a nested family but it doesn't work.
I reckon It could be due to the sweep profile, although I don't a clue.
I have attached the rvt family (and nested family). I would appreciate if any you could take a look.
Thank you very much!
Nachricht 5 von 6
Try this one.
Nachricht 6 von 6
How did?
