Is it possible to create dimension lines such as the second example:
Now I've manually changed the text to that value, but if the distances change, I have to always remember to change the dimension line texts.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Edit: you could do that with a line based detail item
Yes you can also do with the dim style by doing the following
See GIF below
