dimension line broken when text is opaque, anyway to make it continous?
2 ANTWORTEN 2
Nachricht 1 von 3
532 Aufrufe, 2 Antworten
Hello, everyone,
When text is in Opaque, the dimension line is broken nomatter how far the Offset is; is there any way to make it continous? see attached picture.
2 ANTWORTEN 2
Nachricht 2 von 3
Sahay_R
als Antwort auf: Anonymous
When you hover over the text, is the bounding box around the text above the dimension line? If it is going through the dimension line then you will see a break. Play with the offsets a little more, possibly switch fonts.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 3
kadmonkee
Select a dimension and go into EDIT TYPE and confirm the Text Offset value
in the image the first Dimension was manually moved over the Dim line the second Dimension was not moved.simply change the value of the text offset to the result you want within that particulare Dimension Style.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
