Dimension issue Revit LT 2019
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
davids327
480 Aufrufe, 4 Antworten
The dimension function is not working for me, the top option shows the data and lines but will not stay visible when going to other functions. The bottom one shows no value and is just a line that disappears on mouse click.
Any ideas on what I'm doing wrong here?, tried many online videos but none show this issue. thanks Dave
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: davids327
That's the Measure Tool not the Dimension Tool.
...may I also point out that there are two Measure tools: Measure Between Two Elements (the one you are currently using) and Measure Along Element.
Measure: http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-65EA44EC-C777-4C97-8718-5783C3A80B0A
Dimension: http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-E0FB313E-CE57-4741-9EF5-6747BBA3BDDB
Nachricht 3 von 5
Avaris.
You need the button right below the tape measure, which is called 'Dimension', shortcut DI
Nachricht 4 von 5
als Antwort auf: Avaris.
You know, I can see how it would be confusing to a brand new user. The Dimension tool is located on the "Measure" Panel. I never noticed this before.  But I normally access it through the Quick Access Toolbar -- or keyboard shortcut, as you mentioned.
Nachricht 5 von 5
davids327
als Antwort auf: barthbradley
thank you for the tip, I did see this but was using 'linear' and not 'aligned'.
