Dimension from Boundary sketch to Project
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
366 Aufrufe, 2 Antworten
Is their a way of pulling through the dimensions I am creating for something like a floor boundary into the main view? I notice when I finish the command my dimensions will disappear?
2 ANTWORTEN 2
Nachricht 2 von 3
planner_matlabi
als Antwort auf: Anonymous
Hi
yes But You can Dimention change to Parameter in Global parameter
please See Screen Casts
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
Nachricht 3 von 3
constantin.stroescu
There is a workaround for this:
  • In sketch mode select the Sketch and all the dimensions
  • from Modify > Clipboard > Copy to Clipboard
  • Finish Edit Mode (exit from sketch mode into project mode)
  •  Clipboard > Paste > Paste Aligned to current view - and the dimensions appear.
  • Now, because the Dimensions comes with model lines , we'll have to Lock the Lines to the Floor borders and thus the changes made in sketch mode will change automatically into project...
Constantin Stroescu
