Does Revit have any Capabilities for changing the witness line extension line type?Except the Centerlines.
Are you referring to "Witness Line Gap to Element"?
Nevermind. You mean Line Pattern; right? What Line Pattern?
... yes
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Seems tough
but if its one off then you might look at override graphics element...
and keep two dimensions at the same location..
Thankyou Ganesh, I've check override graphics item too. but it seems it changes all the lines in the dimension.I want to change just the witness lines, not the line above them.
True,Is there any way to change all of the extension lines in dimensions? not only the center line?
pretty tough.
there are no sittings for that Guess.
and even seems impossible using any VG..
