Dimension error
11 ANTWORTEN 11
Nachricht 1 von 12
1362 Aufrufe, 11 Antworten
Dimension error
All dimensions of my drawing are different from Actual Value
The correct thing would be that all the dimensions have the same value in Actual Value.
Tags (1)
Beschriftungen (2)
11 ANTWORTEN 11
Nachricht 2 von 12
RDAOU
als Antwort auf: Anonymous
@Anonymous
You have selected a chain/multiple strings dimension...that 914 corresponds to 1 dimension in that chain. Zoom out and check which one it is...otherwise use a single dimension string ... double click that and verify. The values would/should match
Nachricht 3 von 12
Thank you for replying me.
I used a single dimension and the error persist.
Nachricht 4 von 12
Martijn.Pater
...1140 = 1140? edit: aw you mean the actual value field isn't corresponding as expected... No idea really, never seen it, maybe try restarting Revit & audit the file...
Nachricht 5 von 12
ennujozlagam
try to check your alternate units formats?thanks
Nachricht 6 von 12
als Antwort auf: ennujozlagam
I checked the alternate unit formats and it error persists. :enttäuschtes_Gesicht:
Nachricht 7 von 12
als Antwort auf: Martijn.Pater
I did it but it didn't change. :enttäuschtes_Gesicht:
Nachricht 8 von 12
ennujozlagam
can share part of the files so we can check, copy and paste into a new file? thanks
Nachricht 9 von 12
Did anyone ever figure this out?  I'm having the same issue only since upgrading a 2018 model to 2021 version.
Nachricht 10 von 12
michael.coviello
Hello and thank you for posting.
If you have not tried already,  Here are some suggestions.
Does the problem happen when opening the same model on a different pc?
Opening with Audit.
Does the wrong value always show as 0?
Is Revit 2021 using the most recent build?
How to tie the Build number with the Revit update
Also, you tried clearing your %temp% directory and rebooting the computer?
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Nachricht 11 von 12
suwailinn538
Hello everyone.
I would like to know that how can I fix the dimension text error in Revit. Actual measurements value is always different with "use actual value" in dimension text.
Nachricht 12 von 12
suwailinn538
How's about the dimension text error in your laptop. Now, I am facing with this problem. If you got some ways, please share me.
