Dimension doesn't work with levels
9 ANTWORTEN 9
Nachricht 1 von 10
1079 Aufrufe, 9 Antworten
Hi, When I select a level I used to change the dimension, but I can't modify them anymore and they are not locked. Thanks for help
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
Find out, I should activate the dimension, but I can't active forever. Should I do it each time?
Nachricht 3 von 10
Sahay_R
Can you share a file that shows the behavior?
Are the levels from a linked file?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 4 von 10
als Antwort auf: Sahay_R
Sounds like you have hidden constraints. Toggle the "Reveal Constraints" button to investigate.
Nachricht 5 von 10
The file is so big, however, the levels are not linked, I am just wondering why some of the levels have 'active dimension' and some don't. Thanks
Nachricht 6 von 10
als Antwort auf: barthbradley
Nachricht 7 von 10
kadmonkee
by your image
the levels that are blue have views associated to them
the levels that are gray do not have views associated to those levels.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 8 von 10
...because the file IS so large. This is typical behavior. Revit has reached a point where it won't show temporary dimensions because it would impact performance.
Nachricht 9 von 10
Run this test:  create a new elevation or section and see if you can change the grid elevation without activate the dimension.
Nachricht 10 von 10
als Antwort auf: ToanDN
When I create a new level I don't have active dimension.
