How do you dimension the centerpoint of an arc or circle? When I try, nothing is recognized to snap to at the center's crosshairs.
Gelöst! Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
Select the arc wall. In its properties, activate "Center Mark Visible". Then dimension the distance between the center and the grids.
What if it's not a wall, you're measuring, but rather a structural slab that you need to identify a radius for?
