Hi. Our clien has a unit in flow parametr as 850 m3/h and when I export it to IFC it converts into 0.24 m3/s. Is there any way as to how to force IFC to keep the same unit values as in Revit ?
it is a bug. make sure you are using SI units
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Hi @havranon
Thanks a lot for posting your question to the forums! Have the solutions suggested by [@vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
