Different size wall elements (pattern) in curtain wall
damian_anoep
damian_anoep
Hi guys,
I have a issue and I hope you guys can help me out!
I am kind of new to Revit and I need to make a curtain wall of standard wood elements. Those elements are standard 600 mm in width. When I make a curtain wall of 1800 mm in width for instance, the curtain wall should contain 3 of those 600 mm wood elements. I just can't figure out how to do this. And also, when I make a curtain wall of 2200 mm for instance, it should contain 3x 600 mm and 1x  400 mm wood elements.
Do you guys know how I can get this or where I can get this?
Attached you will find an image of what I mean. (note: The elements in the image are 3 seperate curtain walls.
Thank you in advance!
Damian
handjonathan
Hi @damian_anoep
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
