Different grid line layout on different levels
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
AidanHawkins
512 Aufrufe, 5 Antworten
I have a building with several different grid line layouts for each floor
They seem to show up on all my levels even when in two 2..
When I go to propogate extents it will not let me select levels below the level I have created the grid lines
Is there another thing I should be doing here?
Aidan
5 ANTWORTEN 5
Nachricht 2 von 6
Yien_Chao
als Antwort auf: AidanHawkins
the grids is visible on level IF one of the extend cross that level. By the extend, i mean 3D extends, not the 2d.
Nachricht 3 von 6
AidanHawkins
als Antwort auf: Yien_Chao
How come the 3D grids don't extend down.
And how can you bring them down?
Aidan
Nachricht 4 von 6
Yien_Chao
just strech it. if you CAN't , check if the grid i binded to a scopebox.
Nachricht 5 von 6
AidanHawkins
So just stretch it up and down in 3d view? that can be tricky
Is there an easier way to strech it
Aidan
Nachricht 6 von 6
Yien_Chao
well, tricky yes if you dont know what you are doing, but in a project every grids and levels extends are replace sometimes. Also, there is some addins to this by batch (dont remember the name)
