Hi everyone.
I've a topography, I splitted it in 3 parts and I'd like to have different contour line settings on each one. It's possible? How?
I'll let you a capture. I want the red contour line at intervals of 2.5 meters, the bue contour line at intervals of 0.50 meters and the gray contour line at intervals of 5 meters.
Gelöst! Gehe zur Lösung
Gelöst von TripleM-Dev.net. Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
This will take a combination of View Filters and Visibility/Graphics changes.
View Filters for split surfaces
Main topography contour lines' color
The question is not about how to change colors in each topography, but how to have different intervals of contours for each topography. Since those settings are global for each project, probably the user needs to create separate files, use a different interval in each file, and then put together the files as links.
Having different contour levels for topography isn't possible in one and thesame Revit project file.
Depending for the Reason you can put the 2 of the 3 part in 2 different revit files and set the contour levels according. (+ maybe use designoptions to keep originals in main project)
Then link the 2 revit files, this should do the trick. (maybe even create a 3D and levelview in the links to reference to for any other overrides.)
Exact workflow will depend on desired result. project scope/editing etc.
- Michel
From your description, it just sounds like you want to add colored intervals. Add some more Toposurface Subcategories under Manage=>Object Styles and then assign them to Additional Contours under Massing & Site=>Site Settings like this:
If you want to override contour colors or line patterns in certain view, do it the typical way through VGOs.
