Difference between Students' and licensed versions of Revit 2016
13 ANTWORTEN 13
Nachricht 1 von 14
2799 Aufrufe, 13 Antworten
There is a difference in functionalities of Revit 2016 for Students’ stand-alone version comparable to our corporate licensed version, i.e.
For the analysis-related “Analyze” section - there is a difference in working options available, please see the following figures:
  • This is STUDENT VERSION, downloaded from Autodesk’ web-site, stand-alone version:
  • This is the same “Analyze” section in REVIT2016 software with UCC’s license (from another PC):
We are really looking for a solution to this issue, where the possible options could be:
  • Install some additional plug-in (which gives the full energy analysis functionality, same as we have in full-licensed Revit 2016 version)?
Would you be so kind to advise for a possible solution to this problem, please?
Thanks in advance,
Andriy
13 ANTWORTEN 13
Nachricht 2 von 14
Mark.Lancaster
als Antwort auf: Anonymous
@Anonymous
Welcome to the Autodesk User's Community..
What is a student version doing in a commercial office?
Student versions may have or not have benefits assigned to them like a subscription based benefit has.   Meaning the student version hasn't requested certain benefits that are entitled to paying customers or the student version is not entitled to such benefits.
Mark Lancaster
Nachricht 3 von 14
als Antwort auf: Mark.Lancaster
This is in the university, not a commercial office.
License obtained by the university, and we've paid for it as it should be.
However, some remote students may have this issue at their homes, and that's why this question appeared.
Nachricht 4 von 14
pendean
There is NOTHING posting in these forums will do to change REVIT2016 EDU versions: sorry, this is a support forum, not the REVIT Design Team Access forum.
Try posting in the REVIT forums for experienced REVIT users to help you with possible add-ins or other options for REVIT2016 https://forums.autodesk.com/t5/revit-architecture-forum/bd-p/133
Good luck.
Nachricht 5 von 14
Mark.Lancaster
@Anonymous
Like I said a paid subscription version may contain benefits that student versions is not entitled to or the student never requested that benefit.  I'm not a Revit user so I don't know what this function of Revit does or what is covered.
Perhaps @ToddRogers-WPM and/or @DarrenP can step in and assist you.
Mark Lancaster
Nachricht 6 von 14
natasha.l
Hello @Anonymous,
Educational software offers complete versions, so equal to the commercial versions with the same tools & features.
I believe you are seeing this because you need to change/customize the toolbar settings. I will also reach out to @Viveka_CD
Thank you for posting. I will move this post to the Revit forum.
Please "Accept As Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Nachricht 7 von 14
DarrenP
i would first check the options first
Big R>options>user interface
Make sure everything is checked under tools & analyses
DarrenP
Nachricht 8 von 14
Sahay_R
als Antwort auf: DarrenP
Major difference - the Student Version will print 'FOR EDUCATIONAL USE ONLY' (or equivalent). The commercial version won't.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 9 von 14
loboarch
als Antwort auf: natasha.l
@natasha.l wrote:
I believe you are seeing this because you need to change/customize the toolbar settings. ...
This ^^^ is the reason. The analysis portions for Structural and MEP analysis has been turned off in the student version you are using.  It shows where this can be changed at about 1:40 in the video on the linked page.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 10 von 14
loboarch
als Antwort auf: Sahay_R
This is NOT true. This plot stamp no longer appears on printouts from a student version of Revit.
(Actually to be totally accurate Revit student versions never did this, it printed a black band at the edge of the printed sheet. The black band said nothing in it thought.)
Jeff Hanson
Revit Help |
Nachricht 11 von 14
Sahay_R
als Antwort auf: loboarch
Actually, no - here it is about the dreaded educational plot stamp -
http://blogs.rand.com/support/2014/04/relief-from-the-dreaded-autodesk-educational-plot-stamp.html
See it all the time in the classroom. I will verify again during class time this coming Monday.
Rina Sahay
Nachricht 12 von 14
loboarch
That article is about AutoCAD NOT Revit and it is from 2014.
Looking closer at the article it says this is gone in AutoCAD 2015.
Revit has not had a plot stamp since 2015 or perhaps before???  There was a change in Autodesk policy on this a number of years ago. I believe plotstamps are gone at this point from all of our educational products.
Jeff Hanson
Revit Help |
Nachricht 13 von 14
Sahay_R
@loboarch - I need new glasses LOL!
Rina Sahay
Nachricht 14 von 14
Good morning,
Unfortunately, the option to change/customize the toolbar settings is not solving this issue, all necessary boxes were ticked from the beginning.
The only way to sort this out, perhaps, is to reinstall the whole package, which is not desirable. This would be the last option for me to try, but if nothing will appear - have to do this.
Andiry
