I am facing a software interoperability problem, I explain myself:
- Revit model is georeferenced: NS: 7338965410,300 mm; EO: 8959075351,100 mm; Elev: xxx
- I export the model in IFC format, and the coordinates are rounded: NS: 7338965411. mm; EO: 8959075352. mm
This poses a problem for exchanges, as there is a gap between IFC models from Revit and other software (Tekla type).
Do you know how to export a Revit model with the real coordinates of Revit, that is without rounding?
Thank you
