Diameter Symbol in Text
Todd_N
Message 1 of 30
Todd_N
I'm trying to add a diameter symbol to a text box. Can somebody tell me how this is done?
Replies (29)
Message 2 of 30
jason.martin
Depends a bit on your font, but holding down the alt key and typing 0216 on the 10key should give you diameter symbol.
The other way to get there is to use "charater map" in windows and copy / paste whatever symbol you want.
jason
Message 3 of 30
ar.manmadharao
Observer
Observer
hold shift button and type ' %%C ' then you got diameter symbol
Message 4 of 30
kirahomeak
Observer
Observer
"%%C" is to create a diameter symbol in AutoCAD
Message 5 of 30
fabiosato
I use ALT+155, you must keep ALT key pressed while typing the numbers.
Fábio Sato
Message 6 of 30
j.hartleyJWF4M
Jasons solution worked for me.
Hold "Alt" key and press 0216 on the 10key
Message 7 of 30
Thanks! Brilliant! Character map saved my day as none of the other suggested ways worked adding a column dimension in diameter.
Message 8 of 30
If you go to the character map on your PC you can copy across any symbol you like into the text spaces in Revit.
Message 9 of 30
Seems as though 2017 doesnt like the "ALT+0216" - on the numpad - for a diameter symbol. Any suggestions for alternatives?
Matt
Message 10 of 30
ennujozlagam
hello, use window character map > select diameter symbol > copy and paste to your Revit text. thanks
Message 11 of 30
i was looking at how to add this to a 'schedule' on google and came across here
Alt 0216 worked
Alt +0216 worked
Alt +155 worked although smaller than above
all within rvt2017
thanks for your help
would be nice if Revit had an advanced text system like Autocad.... Smiley Happy
Message 12 of 30
I had to copy and paste from Word, to get it to work.
Message 13 of 30
Alt 0216 and Alt 155 is not diameter, it is norwegian letters that looks almost like diameter.
For Windows, it is Alt 8960 for diameter.
Message 14 of 30
i can only get the 0216 & 155 to work in shedules, alt 8960 doesnt seem to do anything within my version of RVT 17
within text, neither works....
Message 15 of 30
s.borello
Hold alt + 0216.
Message 16 of 30
DGTIES_BD
This is actually the right symbol used in Revit, if it needs to be used for filtering in lists. Thank you
Message 17 of 30
LEENAVE3948
Just right-click the mouse to get commonly used symbols. it will also give you access to the character map for other symbols in the font style that is currently being used.
Message 18 of 30
abdaalahmed
Community Visitor
Community Visitor
The diameter can be inserted by using alt code or shortcut code in word.
0216 is the alt for diameter and you can make it by pressing Alt key and 0216 on the numeric keyboard.
You can also copy it from here "Ø."
If you want to know the all methods of inserting dia symbol in different devices you can click here.
Message 19 of 30
m_champine
I LIKED THIS SOLUTION BECAUSE IT WAS SIMPLE TO SEARCH WINDOWS FOR THE CHARACTER MAP APP , THEN SELECT THE FONT I'M USING, THEN THE CHARACTER. YOU HAVE TO USE THE COPY BUTTON IN THE APP APPARENTLY, RATHER THAN CONTROL C.
Message 20 of 30
m_champine
WOW! THAT'S REALLY EASY!
