WANTED: list of ideas as to restoring a dialogue box (in this case Warning), so far I've tried:
Restarting programme
Opening another project
Alt-spacebar arrow trick
changing screen resolution
Is reinstalling the software my only hope... ![]()
Gelöst! Gehe zur Lösung
Gelöst von indiana_j0nes. Gehe zur Lösung
Try and locate the Revit.ini file.
Before you follow any further instructions, just make a backup of this file and also note its path.
Now in the ini file look for the following lines:
SuppressShowButtonMessage=0
SuppressShowMassWarning=0
If they are set to =1 change them to =0
That should ideally do the trick.
Let us know.
Cheers, K
Kunal Tuljaram Gaidhankar
Not sure what you are looking for, the warning like mass visibility, Raster printing, or the warning of model that you can access from Tab?
Is this a recent issue?
From an another thread it appeared to be a bug form a Infraworks Updater.
Maybe check that?
Something Similar but with Revit 2020 discussed here..
YES!!! uninstalled Infraworks Updater and seems to be working fine now.
Just as a matter of interest, I'm running Revit on a double screen.
Thank you
