Diagonal Wall
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
noenoeTRQJM
516 Aufrufe, 6 Antworten
Diagonal Wall
Hi, I am a newbie to Revit. How do I manage the diagonal wall, which seemingly not connected to the beam. I use tool "Join Geometry" and it is not working.
6 ANTWORTEN 6
Nachricht 2 von 7
Ramina_B
als Antwort auf: noenoeTRQJM
Is the column a structural one?
Nachricht 3 von 7
vitorbortoncello
Do you wish to extend the wall? use Extend
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 4 von 7
noenoeTRQJM
als Antwort auf: vitorbortoncello
I've tried. I guess it can only use for walls.
Nachricht 5 von 7
noenoeTRQJM
als Antwort auf: Ramina_B
No. It is the Archi columns.
Nachricht 6 von 7
jay_colcombe
Try using the same material for all elements
Also review the Join Tool as you can Switch orders
Jay Colcombe
Autodesk Certified Instructor
Nachricht 7 von 7
Ramina_B
If nothing work you can use cut profile, but be aware that it's only a 2D solution...
