I have following problem while creating a family. A tube should be always aligned with the diagonal of an rectangle. The width and height of the rectangle has parameters. The diagonal is defined as reference line, both ends are connected to reference plans left and right . The tube is aligned with reference line and should follow each situation. Unfortunately it doesn't. Revit 2019 can't keep the connection.
01.JPG - situation before flexing
02.JPG - situation after flexing
Gelöst! Gehe zur Lösung
Gelöst von denis_kraenert. Gehe zur Lösung
Tried in 2017, it works fine.
I modelled the tube as a line-based family, not sure about work plane based, might work too.
Solved in Revit 2019
- the work plane within the reference line must be selected before placing the familiy
- it must be selected the work plane vertical to the reference plan
- after this it works fine
-@Autodesk why that is not clear described, wasting 1 day just to find that out...
