Devices not showing
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
pmercader
2376 Aufrufe, 6 Antworten
Devices not showing
Im in a weird situation here, but first let me preface with I have little Revit experience currently. So here is my issue, I am opening this revit file that I have worked on before and data and comm devices that I have placed before had disappeared. I asked a teammate if he can see the devices so he opens the same file and he see's it in the same views and sheets I am looking. What would be the culprit here? Is this a personal setting?
Thanks in advance.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: pmercader
Could be any number of reasons -- even some not on this list.
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Nachricht 3 von 7
pmercader
als Antwort auf: barthbradley
My former employer used ideate software. I miss it.
Nachricht 4 von 7
HUH??? I provided a link to a list of 33 Steps to Find Stuff in Revit.
Here's another one to check:
#34. Loose nut behind the keyboard.
:zwinkerndes_Gesicht:
Nachricht 5 von 7
pmercader
the link you provided is from ideate. Its a software solutions group that has a revit plugin. It was very useful to find the cause of hidden elements.
Nachricht 6 von 7
You don't need a plug-in to check to see if:
1. The element or category is temporarily hidden
2. The element or category is hidden in the view
3. The element is being obscured by another element
4. The element’s category or subcategory is hidden in the view
5. The element is outside the view’s view range
6. The view’s far clip depth is not sufficient to show the element
7. The element resides on a work set that is not loaded within the project
8. The element resides on a work set that is not visible in the view
9. The element resides on a work set that is not loaded in a linked file
10. The element resides on a work set that is not visible in a linked file
11. The element resides within a group (detail model) and it has been excluded from the group
12. The element is part of a design option that is not visible in the view
13. The element is part of a linked file that is not visible in the view
14. The element has one or more of its edges overridden to display as “Invisible Lines”
15. The element is a family and none of its geometry is set to be visible in the view type
16. The element is a family and none of its geometry is set to be visible at the view’s detail level
17. The element is set to not be visible at the category’s detail level
18. The element has been placed outside the view's crop region (visible extents)
19. The element is an annotation element and does not reside entirely within the annotation crop region
20. The element’s phase settings or the view’s phase settings prevent the element from displaying in the view
21. The view’s discipline is prohibiting the visibility of the element
22. The element is affected by a filter applied to the view
23. The element is subject to an element override, set to background color
24. The element is subject to a category override, set to background color
25. The element style is set to background color
26. The element is constrained to a scope boxes that is not visible in the view
27. The extents of the element itself don’t permit it to be seen
28. The element is a mass, and “Show Mass” is turned off
29. The element’s host view has been deleted (area boundaries)
30. The view’s scale is prohibiting the element’s visibility
31. The element is a linked instance with coordinates too great for Revit to handle
32. The user has incorrectly identified the link instance to which the element belongs
33. The element is in a link that is not in its correct position
Nachricht 7 von 7
pmercader
The culprit was the workset.
