Determine which direction doors are headed (to and from)
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
lshannonEQEBT
476 Aufrufe, 3 Antworten
Hello all,
Is there a way to determine which direction a door is heading (i.e. to which room and from which room) after it has been placed? I know that you cannot change this once it has been placed, even if you flip and rotate the door, but I just don't know how to view it afterwards.
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
JasonKunkel
als Antwort auf: lshannonEQEBT
You could make a schedule and add the To Room and From Room names and numbers.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
Nachricht 3 von 4
Sounds like you are missing Flip Controls.
In Family Plan View, go to Create Tab=>Control Panel to pick and place Flip Controls.
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2018/...
Nachricht 4 von 4
lshannonEQEBT
als Antwort auf: barthbradley
@JasonKunkel
:grinsendes_Gesicht_mit_Schweißperlen:Yep. Totally didn't even think about the most basic solution. Thanks!
@barthbradley
I have the flip controls in the families, however even if you flip it, it is just the symbols that flip, not the To/From parameter.
Thanks folks! Right now I'm making a Dynamo graph that will draw a line from the door to it's To Room, and then allowing the user to select multiple doors to have swapped. There is a node that does it super easy.
