Detail Level Issue in Revit 2023
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
marilyn_cuellar
534 Aufrufe, 5 Antworten
Hi, I'm new in Revit and have an issue with the Detail Level in Revit 2023.
Additional Information: options of detail level are not grayed out, I can click on them, but there is no change in the drawing.
What I'm doing: I click on Revit, a menu shows up, under "Models" I click in "New", then New Project, Template File, Architectural File, Create NEW project, click ok and Revit opens.
I start drawing my plan like normal, but when i want to change detail level nothing happens. At first, I thought the detail level was by default in Coarse Level but i noticed doors and windows are not in that level, they keep their details.
Please help...
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: marilyn_cuellar
Nachricht 3 von 6
It depends on how the door and window families are built.  Some may show the same in all detail levels.
Nachricht 4 von 6
marilyn_cuellar
als Antwort auf: ToanDN
I understand that now, but at all nothing, not even the walls, when I click in any detail level there is no change at all on anything, not even what I draw.
Nachricht 5 von 6
Again- what are you expecting to see when you change Detail Levels?
- post has been moderated @barthbradley -
Nachricht 6 von 6
Try a wall type with actual layers, not a standard type.
