Detail Item Formula
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
arshad.k
470 Aufrufe, 2 Antworten
Detail Item Formula
Hii Guys!!!
      Right now I'm working on Detail item family creation, I used some formulas to lock some parameters but
it is not locked in type properties, kindly anybody gives a solution for this.
Kindly refer to the below image for reference.
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: arshad.k
@arshad.k
Add an integer parameter call it "LOCK" and give it the value 1 in the formula column
Then set formula to  WT/2 *LOCK
Nachricht 3 von 3
arshad.k
als Antwort auf: RDAOU
Thanks For your Reply !!!
       For time being I used Conditional Statement to fix this Error.  I think so it is impossible to give decimal values in Integer
kindly refer to the below Image.
