Details groups arent updated after changing one of them:
this is the correct group (the one I changed)
this another instance of the same groupe (not updated)
Am I missing something. (Like an option for automatic updating or something?)
do you have any 3rd party plugin? it could be the reason does not update? thanks
may be you somewhere ungrouped and regroup.. replace with updated group...then try to change... Hope it will helps you...
I have BIMcollab installed, but never had problems before. In a new revit file, I can`t reproduce this strange behavour (with the same plugins).
reaplacing the groups helps (once), but we use many, many groups for annotation. Once replaced a changing again one group the same behaviour seems to appear.
try to uninstall the plugin and reinstall later and see if the same issues. just saying. thanks
nope, also not.
I now create a duplicate of the group, and select all instances in the model of the group and swap them with the duplicated one, to get my drawings correct.
another solution that worked was splitting the imported cad symbols to detail lines. than suddenly revit updeted the other groups too. But this seems to be a workaround to me, not a real solution. And I remove the one plugin that I had.
