Detail Groups need to be ungrouped because I changed the dimension text offset?
4 ANTWORTEN 4
Nachricht 1 von 5
625 Aufrufe, 4 Antworten
I have detail groups in my wall sections that throw up the "changes to groups are only allowed in group edit mode error" when I adjust properties within my dimension family. So I adjust for instance whether the text is transparent or opaque and it asks me to ungroup every detail group in my project. Within the error dialogue it appears that the element within the detail groups that is causing the error is masking regions. An interesting point to make here is that when make a detached model and try this I get a similar error-however there is a reduced amount of filled regions showing up in the error dialogue. Anyone run into similar issues and know of a work around other than deleting all of the masking regions from every detail group?
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Huh?  What dimension properties are you changing?
Nachricht 3 von 5
als Antwort auf: barthbradley
The only property within the dimension family that I am changing is the text offset from the dimension string as well as making the dimension text opaque instead of transparent.
Nachricht 4 von 5
Yah, something else is going on here.  I have no problem changing Type Properties of Dimensions used within Detail Groups.
Can we see your file?  Post it.
Nachricht 5 von 5
There probably is something else going on. I tend to get more errors around detail groups once I turn on collaboration and multiple people begin working in the project. Even if no one else is touching the detail groups. Oh well.
