HAD THIS PROBLEM LATELY, AS I PUT MY CALL OUT VIEW ON THE SHEET, THERE ARE MISSING ITEMS. I'VE CHECKED THE VISIBILITY VIEW, VIEW RANGE,ETC. NOTHINGS SEEMS TO BE A PROBLEM. I 'VE JUST NOTICED THAT IF ITS A DETAILED GROUP MODEL, IT WON'T APPEAR ON THE SHEET. ANY IDEA OF HOW TO SOLVE THE ISSUE PLEASE?
Gelöst! Gehe zur Lösung
Did you also check the workset or reveal hidden to see those missing items?
The detail group or annotation wont be copied from the parent view when you create a callout view or choosing only duplicate option.
As a workaround, you can select those detailed group from the parent view, then paste it into the callout view.
I COPIED THE DETAILED GROUP OBJECT TO CLIPBOARD THEN PASTED IT TO CURRENT VIEW. THANK YOU FOR YOUR KIND HELP!
Thank you. I was hoping there was a quicker way around this issue but this worked just fine.
