Detail Components
26 ANTWORTEN 26
Nachricht 1 von 27
gkwas
1234 Aufrufe, 26 Antworten
Detail Components
I have several sections in my project and most of the detail components have disappeared from the sections, particularly rebar sections and elevations, nominal cut lumber, and joists. Does anyone know why this is happening and is there a way to retrieve them?
26 ANTWORTEN 26
Nachricht 2 von 27
als Antwort auf: gkwas
Detail Items are View Specific Elements - like Annotations.
....you can copy paste aligned to same place the detail items between views.
Nachricht 3 von 27
Are you saying that detail components were in the view but disappeared?  Or are you saying they are in some views and not in some other views?
Nachricht 4 von 27
gkwas
als Antwort auf: ToanDN
I have 15 sections in my project that were all completed. The detail components that I used in the detailed sections have all disappeared. Specifically the nominal cut lumber, wood joist, and rebar sections and elevations.
Nachricht 5 von 27
Have you checked view templates for the visibility of Detail Items?
Nachricht 6 von 27
gkwas
I have, it is all in order.
Nachricht 7 von 27
mhiserZFHXS
Did the sections get slightly off angle by chance? Detail items only show when the view is perfectly perpendicular to the components.
Nachricht 8 von 27
gkwas
als Antwort auf: mhiserZFHXS
There is nothing off axis. It seems so arbitrary. On one of the sections half of a filled region is remaining and half of it is missing, along with the missing detail components. Not all of the detail components, just most of them.
Nachricht 9 von 27
mhiserZFHXS
Half of a filled region? Like its boundaries are unchanged, but some of its just not showing?
Nachricht 10 von 27
gkwas
Correct
Nachricht 11 von 27
mhiserZFHXS
Can you post the project? Or at least some screenshots?
Nachricht 12 von 27
gkwas
See attached
Nachricht 13 von 27
mhiserZFHXS
Nothing attached :grinsendes_Gesicht_mit_Schweißperlen:
Nachricht 14 von 27
tkunsmanWKCCM
Did one of your coworkers maybe go in and delete the components? Can check the sync history to see who was in the model.
If the model is hosted on the Autodesk Construction Cloud (ACC) you can always go to an older sync and download that specific version to copy paste the components back into the projct.
Nachricht 15 von 27
gkwas
Try again
Nachricht 16 von 27
gkwas
als Antwort auf: tkunsmanWKCCM
I am the only one to work in this file and it is not hosted by the Autodesk Cloud.
I really appreciate everyone's efforts and willingness to help!
Nachricht 17 von 27
tkunsmanWKCCM
DId you check to see if they got turned off in Visibility Graphics? Try turning on the Light Bulb to see if they got hidden somehow. Did you move the section marker on plan?
Nachricht 18 von 27
gkwas
They are not turned off or hidden. They have just disappeared. I have never had this happen before and I've been using Revit for a really long time. I'm not sure why some of the detail components would still be there and others not. So, even if something was moved or off-axis, which I'm sure didn't happen for all sections, wouldn't all of them have disappeared?
Nachricht 19 von 27
tkunsmanWKCCM
No, remember that Detail Components are a PER view instance, so if the section marker got moved enough the detail components might disappear. This only happened once I think on a project.
How about any backups of the file?
While this might not hel now, but I would recommend running an Audit the next time you open the file. Should run an audit on files at least once a week (if not more often)
Nachricht 20 von 27
@gkwas wrote:
Try again
What are we looking for in the "After" and "Before" PDFs you posted above?  They are two completely different views so there is nothing to compare.
