Detail Component - Filled Region Rotating Incorrectly
BigPicture045
BigPicture045
How do I get the filled region to stay aligned to the originally created view? I am using a parallel pattern to replicate screw threads. However, the problem is when the detail component is rotated in view, the drafting pattern does not rotate with the component. The "align to element" does not work.
See Screw with wrong filled region pattern:
jay_colc
You have applied the only suggestion i would have recommended, therefore, unfortunately i would suggest if you want the Hatch method you need 2  separate families Vertical & Horizontal with again 2 separate Hatches for correct alignment or more painstaking is to draw the thread lines manually in the family using detail lines.
Jay Colcombe
Autodesk Certified Instructor
Use a model pattern.
