Detail Callout Reference Error
joanna
joanna
Hi all,
I am having trouble with referenced views in detail callouts in sections. All the callouts I place will show the correct sheet but an incorrect detail number, they all show zero "0". The referenced view information in the properties tab is correct. I am using Revit 2020.2, I have not had this issue before or with other versions of Revit.
Thank you!
Did you open the Callout Family and verify that the "0" is actually a Label and not Text?
Post your Project.
Edit the callout symbol family, delete the 0 text and add a label for
Detail Number.
