What I have attempted to introduce is a system to remedy the inelegant solution of adding little pieces of text to detail section and callout tags. Whenever a detail or callout was placed referencing a drafting view detail, a piece of text reading TYP. or SIM. was added to the tags that needed it (for a column, for instance). My solution was to add a reference label to the tag family and create view types with the reference label filled out to TYP. or SIM. as needed - so I would have, in addition to the standard detail view, a DETAIL TYP. and a DETAIL SIM. view type. Pick the view and apply it to the callout as needed. Seems simple enough, right? Here's the problem - when I have two callouts referencing the same drafting view, both of them will insist on being the same view type. So if I have two callouts referencing drafting view A and I want one to be TYP. and the other SIM. it won't happen. They will both insist on being the same. GAAHHH. Any ideas? Solutions? Please?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
