Detail callout disappearing after editing the crop size
benj
benj
This is a new issue, to me @ least.
I created a spot detail call out section. Of course when i go to view, its the entire project that's been viewed. Then i edit the crop, create a new box. Then close. Right after that, my call out disappears.
I'm running the 2017 version Revit from the co.'s AEC suite.
roxana_vatrici
Autodesk Support
Autodesk Support
Hello @benj ,
Thank you for using forum for Revit!
Can you please upload a sample in which could be reproduce the behavior on your side?
Any other steps in reproducing it would be very helpful.
Thank you,
Roxana Vatrici
benj
I could share u the entire file. since its huge ill ul in a cloud storage & share u the link. Is that ok w/ u?
The screen shots i can place in the next response.
Thank u for ur reply...
roxana_vatrici
Autodesk Support
Autodesk Support
Hello @benj
Yes, please, share the file and mention which is the crop section, view...A short video will be very helpful to understand the behavior on your side.
Have a great weekend,
Roxana
roxana_vatrici
Autodesk Support
Autodesk Support
Hi @benj ,
Can you please tell me if you need more help on this case?
Thank you for time,
Roxana Vatrici
Hi Roxana.
Apologies for the very late response. I didn't mean any disrespect.
Seems this issue solved (or disappeared) itself.
Thank you for your response...
