Desk Visibility
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
1542 Aufrufe, 10 Antworten
Desk Visibility
I'm using a chair family and a desk family both from Steelcase but when I place the chair partially beneath the desk the seat appears above the desktop (see plan picture). They are both sitting at the same level (see section picture). Cut plane is set to 4'-6".
When I go into the desk family editor and select the components that make up the desktop:
- under visibilty settings I have set them to display in Plan/RCP at all detail levels
- I have confirmed that the "visible" box is checked
Any thoughts on how to make the desktop opaque in my model?
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
Family files are attached here for reference
Nachricht 3 von 11
I turned off the chair's masking region and let 3d show on plan.
Nachricht 4 von 11
als Antwort auf: ToanDN
That helped in that now the desk line runs through the chair, but I'm still seeing the portion of the chair beneath. The weird part is that the desk is set to 'opaque'.
Nachricht 5 von 11
What portion?  I see the desk covering the chair in my screenshot?
Nachricht 6 von 11
Sorry I thought my screenshot attached in my last reply. See attached.
Nachricht 7 von 11
Use the desk family I attached earlier too.
Nachricht 8 von 11
Sorry I've been replying through my Outlook so I didn't see the attachment. Works great, thanks a lot!
Nachricht 9 von 11
Nachricht 10 von 11
als Antwort auf: barthbradley
Thanks! I’m away from the office for a couple weeks but i’ll check it out when I get back.
Nachricht 11 von 11
Maybe the problem is with the table. Did you try adjusting the height of the table? The thing that most people don't know is that on most desks there are always indications on the side or in the instruction book, as to how high should you adjust it. The new artist desk that I just bought from https://trimthatweed.com/best-desk-for-artists/ is just exactly the same. As an architecture, it's extremely important for me to be able to work comfortably so I got a glass desk. Well, mine's a bit different since it's not a family desk like yours, but you get what I mean.
