Design Options
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
zs-17
1398 Aufrufe, 14 Antworten
Design Options
Hi
I created a design set with 2 options, my objects are already set between the 2 options. I want to transfer some objects for example from option 1 to the second. I get an error message that prevents me to do it. If I delete an option, all included objects will be also deleted.
I want to be able to control my objects between options. How to do it, please?
Many Thanks
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: zs-17
Clipboard Cut (or Copy)/Pasted Aligned to Same Place between Option Sets.
Nachricht 3 von 15
ennujozlagam
you can refer to this Article and see if helps. thanks
Nachricht 4 von 15
zs-17
als Antwort auf: barthbradley
Works with some objects only. I can't paste to the Main Model too. Is there a way to paste it to the Main Model or delete the set and to keep my objects?
Nachricht 5 von 15
zs-17
als Antwort auf: ennujozlagam
I didn't find all that I'm looking for in the link.
Nachricht 6 von 15
ennujozlagam
have you check this? thanks
Nachricht 7 von 15
zs-17
Yes, I did. What I need now is delete the option set I created without deleting the objects or removing the objects back to the Main Model.
Nachricht 8 von 15
martijn_pater
This makes no sense whatsoever... Just copy the objects to the design sets to include them or to the main model to include it everywhere... or use cut to move it (cntr+X or shift-delete). First copy/cut, switch Active Design Option and then Paste (aligned to same place). Switch and paste to multiple Design Options if it needs to be included in multiple Design Options.
Cut to clipboardCut to clipboard
Nachricht 9 von 15
_Vijay
Try to uncheck this box.  then copy or cut the option.
Nachricht 10 von 15
Clipboard Copy/Cut and Paste will work. I think you will make life much easier on yourself if you set up and switch between DEDICATED VIEWS.  There is no Design Option Workflow without Dedicated Views.  That's my TIP of the day. You'll thank me later.   Promise.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Nachricht 11 von 15
zs-17
als Antwort auf: martijn_pater
I tried this option it works with a couple of objects but not with all objects to remove it to new projects. I didn't understand the error.
Nachricht 12 von 15
zs-17
als Antwort auf: _Vijay
I don't have a problem with the selection, it's with pasting lots of objects.
Nachricht 13 von 15
zs-17
I think the idea is to create a view for each design. It looks like a better idea than Design Options. Does it work after the mess I did in Design Options?
Nachricht 14 von 15
Dedicated Views are part of the Design Option workflow, not a replacement or alternative to Design Options.  As for "the mess" you say you made, I have no idea what you did, but I am certain that creating Dedicated Views will make it easier to "fix" and manage.
Nachricht 15 von 15
zs-17
Ok. Thanks a lot
