DESIGN OPTIONS
3 ANTWORTEN 3
Nachricht 1 von 4
793 Aufrufe, 3 Antworten
DESIGN OPTIONS
Hello there
I have a problem with Design Options in Revit. I would like to make few facade variants. In main Model I set a facade as curtain wall without any divisions. In designs options I want to put divisions in diffrent measurement or distances. Is it possible to do this? Right now when I want to editing curtain wall (to put divisions) in design option mode it's blocked.
Tomasz
3 ANTWORTEN 3
Nachricht 2 von 4
cbcarch
als Antwort auf: Anonymous
-You will need to place a second curtainwall, with the divisions, in the Design Option.
-Leave the original curtainwall without divisions in the Main Model.
-Set up your view to show the design option with the curtainwall w/ divisions.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 4
Elements in a Design Option must be entirely independent from elements in other Design Options. In your case, move the undivided curtain wall to one Design Option of a Option Set, and create a divided curtain wall in another Design Option of the same Option Set.
Nachricht 4 von 4
Elements that depend on another element must be in the same design option.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
