Design Options - Wall overlapping issue
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
ctough
1536 Aufrufe, 14 Antworten
I've recently been using design options to some success and have implemented the correct views in my template etc- great! However, I have recently noticed that if I draw two individual walls, one of top of the other, both of which are assigned to their respective options, I get a section missing from Option 2, due to Option 1's wall passing through it.
No sure why this is happening, surely one option shouldn't affect the other. Any ideas please?
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: ctough
Did you join the walls? Looks like it. Join Geometry removes volume at the union.
Nachricht 3 von 15
526996629
Maybe try cut and 'paste to same place' when you drop the wall into another option.
Nachricht 4 von 15
ctough
als Antwort auf: barthbradley
No, haven't joined walls.
Nachricht 5 von 15
526996629
Or maybe post your file so we can directly have a look
Nachricht 6 von 15
ctough
als Antwort auf: 526996629
If I paste Option 1 wall into Option 2, then I get this:
Nachricht 7 von 15
ctough
If I try and put a door over the clashed area, I get this:
Nachricht 8 von 15
526996629
The door and the wall are not in the same option. One might be in the main model and one might be in the option.
Nachricht 9 von 15
526996629
Attached file for your reference. If your problem still cannot be solved, I suggest you upload it for review.
Nachricht 10 von 15
ctough
Thanks for sending that project across, that's proof that it can be done.
Please see my template attached, I've removed company work sheets, logos etc...
Open Proposed>Master to view both walls and then each Option view
Nachricht 11 von 15
526996629
No file attached
Nachricht 12 von 15
ctough
Can't upload!
Try this:
Link removed by OP
Nachricht 13 von 15
526996629
You have 2 design option sets rather than 2 design options. If these walls are for 2 design options, there put them in different options in one design option set. Doors: go to the design option and then place the doors.
Nachricht 14 von 15
526996629
Please note that design options and design option sets are different.
Nachricht 15 von 15
ctough
Right... gotcha! The reason there are two set, is that we have to split proposed models up into different planning applications. So looks like I need to add another 'Option' to each set.
Thanks for your help with this, greatly appreciated.
