Hi all,
I prepared 2 design options which I want to show within 2 different sheet sets within the same file..
but apparently I cannot pick different design options for different sheets?
I would like to have the entire package ready to be plot in one go.. without having to switch between active design views?
Thanks!
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
you can refer to this LINK previous thread and see if helps. thanks
or you need to duplicate the view to set design options. thanks
If you have design options there is a category under VG for design options, where you can specify which option to show for that view.
... also known as dedicated design option views:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
